There is a switch on the back with High, medium and low positions. I’ll get some more pics up later.
I would certainly want to see inside to make sure what has been done is reliable and safe. From the outside it looks like a real mess.
i should have mentioned it’s runs smoothly and sounds awesome, the attenuation also works.
It will have needed a small extra transformer fitting to drive the 5V filament since there isn’t a winding on a Twin PT.
Massive, massive amounts of bodgery and bad workmanship. There's so much wrong it's difficult to know where to start.
It's not easy to see if it's actually definitely safe. Personally, I wouldn't even turn it on until it's been properly assessed by someone who knows what they're doing.
Sorry to be the bearer of bad news .
It was a bit of a gamble, but sounded good when I went to pick it up and still sounds good.
Amp tach recommendations in the Croydon/Redhill area?
Henk Phillipson in Horsham is worth a shout or Dickinson’s in Crystal Palace.
I'd maybe leave what's on the stripboards, they don't look too bad - although I would want to see what's under that tape - but most of the rest needs to be redone far better. The PT could stay too, and that certainly does explain the valve rectifier! Interestingly it's been done like a Mesa Dual Rec in that both of the end sockets are wired for rectifiers, so you could actually fit two 5Y3s if you want it really saggy...
I suppose I should have noticed the randomly-angled OT and choke in the first pics, I can't believe I didn't spot that now .
