Do you have a photo of the back of the headstock?
Instagram
Thankfully the original seller was totally honest and accepted the guitar back (he isn't the one selling it now). The neck break was pretty clean and went in a v shape from the nut to just after the 2nd fret.
http://imgur.com/gallery/0cdGul2
Now I've seen the photo of it broken I can clearly see some indication of it in the photos of the "undamaged" neck.
“UPDATE:
I’ve been asked by numerous people if the neck has been out/refitted. I’m not aware of any work done to neck and I purchased from a reputable seller. However I have some more detailed photos of the guitar and it looks like the lacquer has reacted where it meets the body. This is not present at the heel, but is on the sides. The guitar plays perfectly and there is nothing to suggest it’s been damaged, everything is straight and the action/playability is as you’d expect (flipping great) from any PRS”
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
I have to say it was also an unusually poorly-chosen piece of wood in the first place - the grain runs out at quite an angle to the neck, which is why it was able to break like that. That's something I haven't seen on any other PRSs I can remember - although it's fairly common on Gibsons.
@ICBM Just trying to understand as I look at the pictures, is it the way the grain lines angle across the the back of the headstock, rather than running in a straight line between the two lines of tuners?
If anything, you want the grain to run off slightly the other way so it follows the angle of the headstock to some extent and helps strengthen the weak point under the nut.
