So i play both electric bass and acoustic guitar. I fingerpick a lot of steel string folk stuff and my nails are pretty damn important to the sound.
However, i despise the sound of my nails on the bass strings and that attacking sound and always have. I prefer the muted thump of nailless finger tips.
Where do you suppose i find the middle-ground? I've tried finger plectrums for the guitar and i hated them, but i only tried the plastic ones and possibly im not using them right? Or maybe some sort of glove is in order for playing bass? Anyone find themselves in a similar predicament?
My best suggestion would be to focus on picking finger choice so you maximise use of thumb on the lower strings and keep the nails for higher. Or possibly keep one finger nail short to use on lower strings as well while leaving the other 3 longer to use the nails on the high strings?
fingers. He sometimes placed his little finger on the soundboard."
“...it must be understood that the strings are not plucked only with the nails, because the sound would not then be very agreeable. The string is first played with the fingertip using the part nearest the thumb, the finger slightly extended (not bent as for plucking with the fingertip only), and then the string is immediately slid along the nail...If the nails are used, runs can be performed very rapidly and clearly. There is an important exception, however. Persons with very long fingers should not play with the nails, because this gives each finger more leverage on the strings and thus diminishes the force used.”
