SOLD Hiscox STD-EF case for Strat/Tele AS NEW £70
Jimbro66Jimbro66 Frets: 2431
edited July 2020 in Parts £
I bought this case some months ago for a partscaster I was putting together. I changed my mind about that so sold off the parts and the case has remained unused and as good as the day it was delivered. The STD-EF is made to fit a Strat or Tele but will also suit other very similar guitars. Keys and tags included. Here are the pics:
With Tele (no, not included ). Note shape for Strat-ish horns
As New: £70
Collection from north Kent or perhaps meet within reasonable driving distance? Can be sent by courier fully insured for £9.98 within mainland UK.
Here's the manufacturer's info:
  • Unique Liteflite construction: moulded from a high-impact A.B.S. plastic with high-tech foam interior padding
  • The design absorbs shocks, offers excellent thermal insulation and a superior structural rigidity
  • The aluminium valance extends deep inside the case behind the plastic shell, into which all the hardware (handles, catches, hinges, etc.) is riveted, greatly reducing the possibility of fittings coming loose
STD-EF Specifications:
  • Material: A.B.S.
  • Lining: Grey crushed velvet
  • Padding: Foam
  • Plastic handle
Internal dimensions:
  • Length: 1022 mm
  • Height: 51 mm
  • Length of the body: 457 mm
  • Lower bout width: 324 mm
  • Upper bout width: 279 mm
  • Weight: 3.6 kg
  • Made in the UK
  • Jimbro66Jimbro66 Frets: 2431
    And up............
    Perfect for that partscaster you so lovingly put together.
  • stanstan Frets: 190
    £ 75  delivered ?
    stan said:
    £ 75  delivered ?
    PM sent.
  • mudslide73mudslide73 Frets: 3094
    If I didn't have a house full of these... the best thing to come out of Cannock since Trapeze.
  • danishbacondanishbacon Frets: 2700
    The gold standard case in my opinion
    The Hiscox case is now SOLD and will be protecting a very nice new guitar.
