Hi all
I have been looking at older second hand laptops to get me started on recording my own music. There's two that have been offered by a forum member, but neither of us are well up enough to know how the specs below relate to how well they would run a DAW programme.
My plan is to initially use one of the free programmes until I get to know what I am doing.
Below are the specs - would either be able to run something like Cakewalk for instance? Sorry that I can't get the columns to line up properly, but it should be reasonably easy to see which is which.
HP Pavilion G72 laptop | HP G5 250 laptop | |
Screen | 17" 1600 x 900 | 15" 1366/768 |
HD | 223 Gb (250) Not SSD | 464 Gb (500) Not SSD |
RAM | 8 Gb | 4 GB |
Processor | i3 - M350 2.27 GHz | i3-4005U 1.7 GHz |
OS | Win 7 Pro | Win 10 Pro |
Power Supply | Yes | Yes |
32 or 64 Bit | 64 | 64 |
HDMI | Yes | Yes |
DVD Drive | DVD RW | DVD RW |
USB ports | 3 | 3 |
Bluetooth | Yes | Yes |
Spec wise both are fine. These models don't have the best plastics for constant travel use but for home use where they aren't constantly opened and closed they will be allright.
Win 7 Pro can cause problems with some interface drivers ... as it needs drivers to be signed and certified before it will allow them to be installed. You can navigate around that on startup but it can be a pain. Likewise Win 10 pro . For audio use your better off with home versions.
Both models can be reloaded with home versions so that's not a deal breaker
How easy is it to load the home versions on a second hand computer?
By interface drivers I am presuming you mean USB audio interfaces. My plan was to get one from ebay and my selection would be based largely on price - does that seem OK or are there ones to avoid?
My tip for cheap USB interfaces is Mbox .... because people think you need Protools LE to run them but they run fine under Reaper and other DAW's but also allow you to use Protools LE8 which is a great home DAW
With a lot of this at the moment I am very much in the mindset of "if I plug this in here will the sound come out there and go into there?" - I'm not a technophobe, but I am used to using things that have been set up and all I have to do is operate them
This will be a learning experience for me on the tech as well as musical side.
