Ibanez SD9 [SOLD], Orange Squeezer clone, Tech 21 Sansamp [SOLD]
KeefyKeefy Frets: 2272
edited January 2021 in FX £
(1) Ibanez SD9 Sonic Distortion 1980s MIJ Maxon-built
This fantastic 1980s pedal has seen me through a lot of gigs and it has the paint chips to prove it. Nothing sounds like an SD9, just don't turn the tone control above 10o'clock! I don't know whether the JRC4558D chip makes that much difference, but it is present and correct.
I have recently replaced all the electrolytic caps (which degrade with age and were causing a switching problem) and the battery connector, and the pedal is now fit for another 35 years of filthy fun.
I am only selling this as lack of gig income has severely curtailed my fun money.
Yours for £80 delivered mainland UK. At least until I change my mind...
(2) Kit-built Dan Armstrong Orange Squeezer compressor clone
This is built around a PCB which I painstakingly checked is a full-on clone of the original pedal. The amount of compression is set by the Bias control (originally an internal trimmer) - be aware that setting this too high will cut off all of your signal! The output level is controlled by a mahoosive knob that you can easily operate with a toe on-the-fly if you want. The internal shot should convince you that this is a neat build. It is true bypass, so there is an audible click when operating the footswitch.
Sounds particularly good with a Strat - think Dire Straits, Skunk Baxter...
Will run from a PP3 battery or a standard centre-negative 9V power supply (neither included).
Condition is as per the photos - there is a little nick in the paint just below the footswitch.
£45 delivered in the UK.
(3) Tech 21 Sansamp PSA-1 programmable pre-amp SOLD
The PSA-1 is a 1U rack device that uses analog modelling to simulate the sounds of classic amps. Effectively you can set separate distortion levels for low, mid, and high frequencies. It comes loaded with 49 presets covering various Marshall, Fender and Boogie amps as well as bass amps. The signal path is 100% analog, but you can save settings to one of 49 user memory locations. The programs can be accessed form Up/Down buttons on the front panel, or by MIDI program change.
The Tech 21 'character' pedals use the same sort of technology but with some of the parameters pre-set to suit the kind of amp they are mimicking. Here you have the full range of tweakability.
The PSA-1 can be considered a pre-amp or an amp simulator, but it doesn't have any onboard speaker simulation as such. It can be used into a clean guitar or bass amp, or into a power amp with a suitable guitar or bass cab. For direct recording most of the (dirtier) sounds also require a cab simulator device, IR loader or similar. Even so, I recorded the clean guitar in this clip without a cab sim.
To me, the standout presets are 07 (Hendrix - Marshall), 12 (Stevie Ray - Fender) and 48 (AC30 Queen). As is usually the case with presets, you probably won't like them all, so copy one you like to an empty memory slot and tweak away.
There are plenty of connectivity options including front and rear inputs, FX loop, balanced outs, and MIDI in/out.
The unit is in full working order. There is an in-line IEC plug/socket part way down the mains lead, which makes it easier to run through rack panels. The only negatives I can find are:
(1) The Up/Down buttons sometimes jump more than one increment at a time (but it's easy enough to go back to where you want to be);
(2) Some of the lettering has worn away on the rear panel;
I don't have a hard copy manual but you can download it here.
Reason for sale: I have used this much less since getting a Revival Drive!
Yours for £250 £220 £200 £170 £150 £130 including UK mainland delivery.
Here's a dude showing off some of the presets:
https://www.youtube.com/watch?v=VlaktWMZgAo
EDIT:
  • I have just refunded the original buyer and this is now back up for sale at just £150 delivered. The buyer reported that the unit exhibited a random clicking in use. I realised this had happened to me once, and I also remembered what it was and how to fix it.
  • When you call up a preset, the unit uses the stored data to set all the parameters. Once you start turning the controls, it 'reads' the parameter values from the pot settings. When you turn a control it updates these values, and you can get a click. Also if one of them is near the crossover point between one value and the next, it can jump back and forth between these values, again causing a click each time this happens. If you save settings to a spare memory location as you go, the clicking goes away. The buyer agreed this seemed to be the case, but requested a refund, which I was happy to provide as this would have been in the description had I remembered it.
  • I have had the unit plugged in this evening and I have been unable to get it to misbehave. However, it can happen, and it is easy to work around.
So, yours for just £130, looking like it does, and with some minor niggles as described here. No trades thanks. These are selling for a lot more on eBay!
«13
