5E3 Vs 5F1
HootsmonHootsmon Frets: 15960
The main differences in clean tone only folks and why you prefer one over the other
studio/recording and home use
tae be or not tae be
  • Modulus_AmpsModulus_Amps Frets: 2576
    5E3 has a tone control, so it works with more guitars/guitar pickups
    5E3 has more "bounce" which makes it more fun to play
    5E3 slays a champ in just about every way, except at being a champ
  • RiftAmpsRiftAmps Frets: 3144
    5F1 cleans
    5E3 cleans
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • ICBMICBM Frets: 72307
    5F1 with 8" speaker vs. 5E3 with 12" - I'd take the 5E3.
    But if you're comparing both circuits with a 12" speaker, I prefer the 5F1... I think it's the negative feedback. I've come to the conclusion that I just don't really get on with amps without it, once they get pushed hard. I even prefer AC30s clean to overdriven.
    I don't like the tone control on a 5E3 really, it goes from not quite right to still not quite right without passing through right, for me.
    The 5E3 has more clean headroom though, even than a 5F1 with a 12".
  • merlinmerlin Frets: 6674
    What are you thoughts on the 5e3 Rob Robinette mod? Does adding negative feedback make a 5e3 work for you (despite it making it NOT exactly a 5e3)?
  • monquixotemonquixote Frets: 17603
    If you have a Helix they have models of both.
    That Julian Lage clip was great.
    Does he have a 12" speaker in his?
    I've never tried it.
  • HootsmonHootsmon Frets: 15960
    John i remember asking you about running an extension cab with the 5E3 (1x12 c90 8 ohm) alongside the deluxe's own internal speaker and you replying it would be OK..........is that still an OK at gig volumes and for a couple of hours at a time and does it shorten power tube life at all?
     @ICBM
    Thanks man  :)
    Yes and yes.
    RiftAmps said:
    5F1 cleans
    5E3 cleans
    Thats some great playing vs some ok-ish demo playing
  • shaunmshaunm Frets: 1598
    RiftAmps said:
    5F1 cleans
    5E3 cleans
    I wonder how many amps that Julian Lage has sold with this video. It couldn’t be a better video to demonstrate that amp. Sensational playing
    ICBM said:
    Yes and yes.
    reduce power tube lives significantly John? ^
    and is there not a Gizmo in this day and age ( a wee black plug in box) that sorts the ohms problem for us?
    Probably not significantly - these amps run them quite hot anyway, so they don't have the longest life expectancy even with a matching load.
    Yes, you can get a matching transformer if you really want to - I've never bothered normally though, unless it's something really incompatible like a 4-ohm amp and a 16-ohm cab. Impedance matching isn't usually as critical as popular wisdom would have you believe...
    Leo Fender was well aware that musicians just plug things in and go!
    thanks John  :)
