But it may not be that straightforward - with such a severe valve short it could have burned out a resistor or damaged the valve socket, so I would be wary about just changing the valve(s) and the fuse - I would want a full internal check and to power it up while monitoring what’s going on.
I agree. It’s going to Dickinson amps tomorrow!
Is that certain models or the way you’re pushing them?
My mojado has done hundreds or gigs and rehearsals and never skipped an beat. Added a shiva a fee weeks ago that I’m hoping to get years of gigs out of. Aside from the usual maintenance and careful handling any valve amp needs is there anything g else to be aware of?
You need someone who really knows how these amps work to get them biased correctly.
does it cut out on the half power mode too? might be a way to trouble shoot the fault as that mode cuts out 2 of the power valves out of the circuit.
+1 vote on reliability tho, I've had a Bogner close to 10 years now and its going strong. Love these amps.
Good luck!
The Shiva head I did gig hard for years but eventually the OT went and it wasn’t the same afterwards after having it replaced. It was also notoriously difficult for the tech to get hold of a replacement from Bogner.
The Goldfinger, I got it home and the presence pot just failed internally. Brand new. The chassis was also a thin, weedy folded bit of steel or aluminium. No ends on it. Not a 3 sided box type thing. The pot was just disintegrated for some reason.
The Shiva combo overheated a lot I.e. the front panel was too hot to actually touch and just didn’t sound right. Again brand new.
The Ecstasy kept lunching preamp valves. Again brand new.
The Barcelona blew the speaker or had a weird cabinet rattle from the get go. Couldn’t get rid of it. Again brand new.
I really like Bogners, but Friedmans are where it’s at for me for the modded Marshall tone. I’ve had issues with all 5 Bogners I’ve had without exception.
Charlie at Bogner actually recommended the Ruby Tubes brand for my Shiva over anything else and they did last longer than anything else "premium" I'd had in there.
