Danplifier Jimmini - upcycled Marshall Lead 12 and mini 1 watt head
4114Effects4114Effects Frets: 3131
edited October 2020 in Amps £ tFB Trader
Picked up a tatty lead 12 combo a while ago, just got round to converting it.
Innards have been gutted and replaced with an improved version of the Marshall Class 5 all-valve amp. 2x 12ax7 preamp valves, 1x 6v6 output. TMB tone controls, gain and master volume.
I've also added an excellent zero-loss FX loop with bypass.
Not high gain, just lots of the vintage Marshall crunch and attack, works very well with a booster in front to push it a little.
10" Celestion VTJR 50 watt speaker complements the tone very nicely.
There is a small amount of yellow spray on the tolex at the bottom of the amp, it's how it was when I bought it. Tolex is understandably tatty in a few places too. Adds to the character and upcycled nature though.
Too many amps in my workshop so a bargainous £350 or nearest offer, trades also welcome.
0reaction image LOL 12reaction image Wow! 0reaction image Wisdom
  • ICBMICBM Frets: 72375
    That’s a very neat conversion. Did you keep the original PCB?
  • I’d have been all over this if it was a hand wired version of the lead 12 circuit
  • 4114Effects4114Effects Frets: 3131
    sadly not, somebody had butchered it beyond recognition.
    Isn't that solid state though?
    What could possibly be the advantage of that? You could easily do it if you wanted to - it's a simple IC and discrete transistor circuit - but the IC contains more individual components than the rest of the preamp put together, so it would still not be "hand wired" even if it made the slightest difference to the sound, which it wouldn't.
    Damn, I was looking for ideas to improve my dead TSL100 combo :).
  • monquixotemonquixote Frets: 17625
    Because it's hand wired man
    Everyone knows handwired is where you get the tones.
    I'm going to build a handwired SHARC for my Helix.
  • SteveRobinsonSteveRobinson Frets: 7032
    Very nice, I did something similar with a Park G10 combo which now has an AX84 P1 inside but my fascia plates are nowhere near as elegant.
  • UnclePsychosisUnclePsychosis Frets: 12902
    Sorely tempted but I'm a Fender/Vox man at heart, don't suppose you have anything Vox flavoured in that overflowing workshop?
    Planning a stripped down AC4, sans tremelo with 10" speaker as my next build, have all the parts in stock ready to go. Can be head or combo :-)
    I meant a hand wired valve conversion
    It wouldn’t work - at least not as an exact copy. The Lead 12 only has two IC gain stages, which isn’t enough to give Marshall levels of overdrive if you replaced them with valves.
    You could build a mini 2203 circuit in one though... I’ve wondered about doing that to one of the heads, but it’s a huge amount of work.
    This one will be in the same ballpark though.
    Bump, any offers on this little beast?
    Here's a lovely little one I've just finished. Will be putting on ebay to take advantage of the £1 fees, but thought I'd list it here too.
    It's an all valve 1 watt Marshall type head. Very diminutive, fits in the palm of your hand.
    2x 12ax7 preamps, one 12au7 output valve for 1watt max power. Ideal for rocking that Marshall crunch at bedroom-ish levels.
    Simple controls - Volume and Tone make it a fun plug and play head.
    Finished in black paisely fabric with custom laser-etched brushed gold control panels.
    £300 or trades for this unique little thing?
    Bump
    Bump, still here :-)
    Bump, still here. :-)
