Speaker cables?
BeardyAndyBeardyAndy Frets: 716
I need to stop spending money on pedals i never use and invest in some new leads!
What I really want is a quality speaker cable, only needs to be short to get from head to cab, but with right angle jacks. Cant see anything other than the budget ones, am i missing something? Why can i buy any number of "boutique" instrument cables with angled jacks but not speaker?
There was someone on here a while back starting up making very nice cables but I can't for the life of me remember who it was!
    I think there's a couple on here, but the only one I tried was @robinbowes and I thought price and quality were good.
  • ICBMICBM Frets: 72369
    Two Neutrik NP2RXs and a metre of 2-core mains cable is all you need.
  • 'Vot eva happened to the Transylvanian Tvist?'
  • ecc83ecc83 Frets: 1634
    "GIVE a man a fish...." Learn to solder! Speaker cables on jack plugs are about the easiest jobs to start on.
    Yes, the initial investment is quite high but a very good Solder Station can be had for around a nifty. Check out "Dura Tool" at CPC etc. Some solder (Lead/Tin 60/40 if you can get it unless you want to start selling cables!) and a some very basic tools, pliers, wire cutters that you might already have. A 50mm vice that clamps to a table is invaluable.
    Now I might get some stick for this but if you buy some HD ~6mm OD balanced mic cable you can use that for both guitar leads, patch cables AND speakers. Or get some cut Orange garden flex from B&Q.
    Dave.
  • fretmeisterfretmeister Frets: 24293
    Most boutique cables are bollocks.
    As long as the actual cable will take the required current and is constructed properly you are all good.
  • vizviz Frets: 10699
    Lawnmower cable is the guitarist’s cable of choice. For some reason.
    It cuts through any mix.
    15reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • BeardyAndyBeardyAndy Frets: 716
    Dave.
    i am fairly handy with an iron, just would rather pay for a good one than mess about making one. I've remembered who it was now anyway, @loadedforbearaudio
    I use old vacuum cleaner power cable - but you have to connect it the right way round or you get tone suck.
    One of the above statements may be true ;).
    Actually I use it because it's free, and it's grey - I don't like black because it's too easy to confuse with an instrument cable. I don't really like orange cable, but if I used Orange amps I would :).
  • normula1normula1 Frets: 640
    I use the cable from the irons my wife gender neutral household supervisor gets through on a regular basis as it generally looks quite pretty and nothing like my other leads.
  • robinbowesrobinbowes Frets: 3042
    This.
    I build them to order, but I don't make any extravagant claims.
    I use Van Damme speaker cable, but decent jacks are the important thing.
    R.
  • thomasw88thomasw88 Frets: 2326
    We've had one iron in the last 15 years.  What's she doing with them dude?
  • sev112sev112 Frets: 2768
    Anyone care to educate me as to why lawnmower and steam iron cable are the same as a speaker cable
    the former would seem to transit current at 240v, whereas I don’t imagine such a current is flowing through to a speaker.
    Is it just extremely over designed when used as a speaker cable and therefore quality is maintained, lots of current headroom if you like?
  • JonathangusJonathangus Frets: 4534
    I think it's just that guitar cable isn't up to the job, and mains cable is cheaper than speaker cable.  Plus they look different from your guitar leads so you don't inadvertently connect your head and cab with a guitar lead.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
    It's all about current handling.
    Speaker output is relatively high current, which is why signal cable is not suitable.
    Mains cable is designed for higher current handling and so works just fine.
    R.
  • TheBigDipperTheBigDipper Frets: 4784
    R.
    And by current, you mean amps rather than volts, don't you? I was once told that I should think of electricity flow as being like a waterfall. The voltage was the waterfall height and the amperage was the amount of water flowing over it. A high waterfall with a trickle of water isn't anything like as dangerous (or cable-melting) as a lower waterfall with a huge amount of water coming over.
    Feel free to enlighten me and shoot this down if it's wrong - I'm just repeating what I've been told.
    They are all suitably rated for speaker use. To be pedantic 240V does not "flow through" a cable it is the current in amps that 'moves'. Worse case speaker load would perhaps be 100W into 4 Ohms and here the current is a theoretical 5 amps. Same as a 1000W iron would pull and garden cable is generally rated at 6A.
    But 100W into 4R 'guitar' would not be anything like 5A integrated over say ten seconds, just as well because many jacks are not rated that high! Anyone ever found a hot speaker plug?
    In fact you could almost certainly get away with a regular, screened guitar lead even for the above scenario (maybe not a curly one!) and definitely for fewer watts and higher impedances.
    Dave.
    R.
    Yes, current == amps.
    https://chem.libretexts.org/Bookshelves/Analytical_Chemistry/Supplemental_Modules_(Analytical_Chemistry)/Electrochemistry/Voltage%2C_Amperage_and_Resistance_Basics
    You might be surprised, if some nutter is cranking out a fully overdriven Status Quo rhythm chord part... not much breathing space in there!
    I have come across hot plugs, but only when used for bass at about 300W. Obviously 1/4" jacks shouldn't be used for that, but they are!
    The only time I've seen one fail was a curly lead which had been used between a 100W (valve) bass head and a 4-ohm cab - luckily it melted and shorted rather than burning out, so it then just took out the HT fuse in the amp... no other damage. The owner didn't realise why, he thought the amp had blown up so badly it had melted the cable - he brought it to show me, which was a good thing as I then realised the cause of the problem and was able to educate him and sell him a nice heavy-duty speaker cable :).
