FS Blue Girl and Red Girl
ricky50ricky50 Frets: 159
edited July 2020 in FX £
I've been looking after these works of art for the nation for the past 3 years since buying them on here from @martinw. Juansolo makes amazing pedals but these have to be amongst his best creations. Together they virtually become an FX unit that would cover most gigs.
https://www.dropbox.com/s/osn7iu52glemq0n/Blue Girl.jpg?raw=1
Blue Girl is essentially Hawkwind in a box with Fuzz, Delay, Reverb and Phaser. I think @martinw had them built to his own spec and his description of the pedal was as follows - the delay is a simplified Zero Point Delay, and the reverb is a 1776 which uses the Belton brick, These are not clones. The Fuzz is a Colorsound Jumbo Tonebender and the Phaser is a Script Phase 90. The switching on these uses optical system, again doing away with the weak point on most pedals, yet still remaining true bypass.
https://www.dropbox.com/s/k1or3xx6rv5riq2/Red Girl.jpg?raw=1
Red Girl is two Timmys and a Guvnor all operating separately and not stacked so you press one switch and it switches whatever else is currently on, off at the same time.  So you can set one Timmy as a boost or crunch and the other as a lead tone or jump to the Guvnor for a different sound.
If you’ve not used Juansolo’s pedals before they are solid as a rock and noiseless. These two are a cut above even for Juansolo’s usual standards.  Here they are together on a Pedaltrain Nano (not included) to give you some idea of their size.
https://www.dropbox.com/s/flfhvoq75lgp00y/Blue Girl Red Girl pedal.jpg?raw=1
Blue Girl  £150 PPG  Posted
Red Girl   £130 PPG  Posted
Sold as pair  £270  PPG  Posted
