Miking up Harmonica
I'm doing a bit of recording with a Harmonica player.  He has a decent sound through an old 50's harmonica mic and nice valve amp, specifically made for harp.  So think fat a nice chicago sound.
Has anybody had any experience miking up a harp amp like this?
I guess it's not that far from guitar so I could just stick a '57 in front at the edge of the cone, but just wondering if there's any convention or tricks that are sometimes used with Harp.
  • octatonicoctatonic Frets: 33846
    Exactly what mic is he using on his harmonica?
    If he is using something like a Green Bullet then you don't want to stick anything too crunchy in front of the amp, because the harp mic is doing that already.
    I tend to use my AEA R84a if the harp mic is crunchy.
    I use a U87 the rest of the time- substitute any LDC in its place- 1-2ft from the mic.
    I wouldn't use a distorted electric guitar approach.
    Consider mixing the harp acoustically too, not just through the amp.
  • menamestommenamestom Frets: 4727
    I'm not sure of the exact mic, but it's definitely one that adds that classic crunch.
    So do you mean an LDC 1-2ft from the amp?
    We have an SE LDC at the room which is quite nice.
    Depends on the room, but if in a good room I find harp needs a bit of distance.
    If you have an untreated room then go closer, but careful about putting it too close.
  • EricTheWearyEricTheWeary Frets: 16301
    https://www.soundonsound.com/techniques/capturing-perfect-harmonica-recordings
    Quite a long article, quick skim through does suggest micing the amp as you would for guitar although also having a parallel signal to mix back in.
  • p90foolp90fool Frets: 31663
    The guy I normally play with has a very dirty amp sound, so I usually record him directly from his mic so I can decide how much to add later using amp sims.
  • McSwaggertyMcSwaggerty Frets: 662
    I use an Astatic JT30 through a small  Harpgear boutique Fender champ type amp....
    I hold back a bit on the volume, to keep on the clean side of dirt...
    I Mike up the amp with a SM57.....
