Spotify audio tinny and thin from laptop
Can anyone explain why Spotify audio sounds terrible from my laptop into my monitors? In comparison to when I plug my iPad and play songs the bass is more present and its fuller sounding? Both settings are the same. Same problem from music from YouTube as well.
Has anyone else experienced this?
  • octatonicoctatonic Frets: 33834
    Is the audio output in your laptop actually a headphone output?
  • LestratcasterLestratcaster Frets: 1093
    Yes it is but so is my iPad or is that an aux?
    It has been a while since I had an iPad with an audio output so I am not sure- probably a headphone output.
    But laptops usually have pretty poor audio specification for the built in audio card, which is why people use external audio interfaces.
    Apple are usually a bit better in that regard, although it is still pretty 'consumer' rather than hifi.
    What laptop is it?
    Do you have the latest driver for it?
  • monquixotemonquixote Frets: 17664
    Probably a terrible soundcard in the laptop.
    Get a USB DAC. Doesn't have to be a super fancy one.
    What laptop is it?
    Yeah the in-built speakers are terrible, so that's why haha.
    It's a HP Pavilion.
    I don't know if I have the latest drivers, probably not. I think I will want to get an interface soon anyway esp if I want to record my guitar through it, they can do that and I can play music via that too right?
    I think you may be right sir.
    Any recommendations? I know nothing about interfaces. Well, only the Focusrite one.
    What laptop is it?
    It's a HP Pavilion.
    Does that have a Realtek audio card then?
    If so yeah they are junk.
    Yes you can generally use an audio interface for system sounds and Spotify etc.
    What laptop is it?
    It's a HP Pavilion.
    Yeah it does. That’ll explain the reason.
    ok is there a do-it-all one that I can connect my iPad, smartphone and laptop to play Spotify off? I run it off several devices and the option to play it off any of them would be good alongside recording guitar.
    Would something like this do the trick?
    https://www.amazon.co.uk/Audioengine-D1-Converter-Headphone-Manufacturers/dp/B006IPH5H2
    Or could I get something similar for less?
    Or should I hold out and get the Focusrite interface if I’m planning to record guitar?
    edited July 2020
    Personally I would hold out for the right thing.
    The cheaper Focusrite devices are about that price and they are fine.
    Hmm I had the same thought. Is it the solo or 212 Focusrite? And what type of cable goes from the line outputs into my monitors? They’re Mackie CR4’s.
  • RockerRocker Frets: 4992
    That is your best option.  Some years back I got a second hand one for little money.  It is connected to my desktop computer and all the music/sounds are going through it to a very old hi-fi system that serves as the audio system for the computer.
    Nil Satis Nisi Optimum
    Do you know what brand it is? Ive seen proper cheap ones for like £15 off Amazon but don’t know If they’re sufficient.
    Either really, although I'd suggest going for something that is NOT bus powered.
    If you go for those devices then you just need a couple of TRS cables I think.
    There’s £30 difference between the two. Bus powered? As in USB?
    And yes I believe it’s two trs cables out from the back of the Focusrite into monitors. As the laptop is windows I might have to download some drivers from the website.
    Bus powered meaning it is powered by the USB bus.
    Compared to having either an internal (IEC) or external (wall-wart or line lump) power supply.
    I think the Scarlett is bus powered. Does that mean it’ll be noisy?
  • robwrightrobwright Frets: 738
    I have this one attached to my hi-fi and it is brilliant! Obviously doesn't sort your recording needs, but for audio from a laptop -top job!
    That's good to hear but I settled for a Focusrite 8i6 in the end - need it for Zoom guitar lessons even though it doesn't pick up SPDIF as an input. Also I use it to run my Kemper out to monitors to mix with Spotify/YouTube etc.
    Playback quality is a lot better than it was, fuller and I can hear extra parts that I didn't hear before on recordings!
