Pros - Ability to do nice trem shimmers, tuning stability
Cons, double bends don't work as well, snap a string and you go out of tune
The most important thing is not to overtighten the front pivot screws - you must be able to pull the bridge back to fully flat without the plate binding against the underside of the screw heads. It's easier to assess this without the strings on - and contrary to popular wisdom, there is no benefit to raising the middle four screws as long as they're all set correctly.
https://support.fender.com/hc/en-us/articles/212774786-How-do-I-set-up-my-Stratocaster-guitar-properly-
I haven't posted photo of my guitar, those are just photos showing the back of the bridge and one is touching and one is not. The question is which one is right/prefered really.
Some have it flat, with 5 springs and the trem will not move - But they feel it adds more 'resonance'
Others still have it flat, but only a touch is required on the arm for down pitch
Others have a touch of up so only slightly raised
Others have more up pitch - J Beck amongst this preference
ref 3.2mm from Fender - I see nearly all C Shop models arrive like this and I adjust accordingly - I can't recall the last time any one required this option
deck let’s you use the bridge purely downward, fixes some of the issues above.
block nothing is moving, it’s a hardtail basically. Gives you the most sustain.
All personal preference. I’ve literally just popped my strat to tech today and have it floating. If I was gigging it I’d have it decked. If I owned multiple strats I’d probably have a variety.
You should be able to get it to about that with the bridge floating slightly and the saddle screws flush with the saddle tops for the Es, D and G, and just slightly above for the A and B. If not, a small shim fixes it.
If you hardly use the trem (like me) deck it.
I obviously need a second strat...
1) remove trem arm
2) throw trem arm in bin
3) add five springs as below
Great for country licks.
