MultiFX also give a smaller stage footprint, fewer leads/connections to fail, and less to carry.
I mainly used it like you suggest, ie scrolling through a few different effects. I have a basic patch of just Noise Reduction - > Reverb, copy that to a few different presets, then add one effect to each preset.:
1.NR - tremolo - reverb
2.NR - phaser - reverb
3.NR - tape delay - reverb
Etc
Then use the footswitch to go between the various presets, using some empty presets to act as bypass mode. It is also a lot of fun to stack various effects but it's quite a bit easier doing that when connected to a pc interface.
Roland is spot on that the sounds won't quite replicate some individual pedals, but the variety of stuff in them for the price / footprint is amazing. And some of the modulations and delays in the Zooms are VERY good.
I just dont have the patience for all that.
Pedals give you the ability to change everything at any time for different rooms/volume but unless you grow a third leg complex changes are out.
There are a number of halfway houses, like loopers manual or programed that give complex patches for a number of pedals. Some pedals have patches which allows for storage of settings but easily overidden,
Some multi effects have loops to allow connection of pedals. TC have done some and the Helix allows for connection of pedals to use with FX and amp sims.
What do you want to do? I use pedals and sometimes a simple looper and or an AB box or pedals in jumped channels. I'm currently running two boards, one with a synth 3 overdrives, trem and a reveb. THe other has one synt a drive and a delay with modulation. For grab and go I'll use a drive and delay or just a drive.
Pedals give you that versatility the multis versatility is that it can do anything and fit in a rucksack as long as you dont mind programming it.
soundcloud.com/thecolourbox-1
It really is a great halfway house - most of the standard effects you’re likely to want, all controlled with knobs not push-button editing, and you can configure it as individual pedals or programmed patches. It does have some limitations, but for a typical second hand price of around £100 it’s unbeatable in my opinion.
Most remarkably of all, some of the digital drive settings are genuinely as good as their analogue equivalents - that’s not an exaggeration, and I am very fussy.
After many years with an analogue pedalboard I am now a confirmed multi-FX user...
1. I wasn't sure which modulation effects I'd end up gravitating towards and I didn't want to buy loads of individual pedals to help me decide.
2. I wanted the ability to have several flavours of each effect type.
3. I wanted stereo ins and outs.
4. I wanted the ability to have two different effects engaged simultaneously with foot switches.
5. The reduced footprint of a single pedal (even one as big as the MD-500) is helpful on a packed pedalboard.
6. The cost is lower than getting high quality individual pedals to cover the same range of effects.
Obviously, some of the points above can be covered by individual pedals, but not all of them. Also, several, but certainly not all, analogue modulation pedals that I tried were rather noisy.
Digital vs analogue with modulation is somewhat subjective, unlike with drive pedals in my experience. I *suspect* that really high quality analogue modulation pedals would be fractionally more pleasing to me, but I've managed to get some excellent sounds from the MD-500. Certainly, more than good enough. The default patches weren't great to be honest, rather sterile sounding. However, with a little work, I've got some much more analogue-sounding ones simply by tweaking the out-of-the-box ones. I've heard that comparable multi-fx pedals from other manufacturers have better default patches, but I can't confirm that and each of these alternatives had its own drawbacks.
I followed the same approach when choosing a delay and reverb (Source Audio Nemesis and Ventris) because I like the flexibility to have a range of delay/reverb types available at the touch of a button. Both of these digital pedals sound analogue enough to me after a bit of tweaking.
My drive pedals (mainly ThorpyFX) are all analogue. Their sound and touch sensitivity are wonderful. Can't see digital replacing them any time soon. If ever.
However I play in multiple bands some where I need to manipulate weird sounds on the go and that’s where I struggle with multi fx. I prefer to be able to turn a knob rather than access a menu on a stage in real time.
Something like the HX FX is perfectly easy in this scenario though. It's foolproof. Very, very easy.
That said, I really want to try a GT-1, which is very much more a traditional multi-FX with programmed patches... I don’t really know why, other than it’s tiny and looks cool .
All very immediate to use in Manual mode. Most of the effects a bassist could wish for - just not all at the same time.
Both boards are perfectly giggable for the bands I play in. I could probably do ok without the pedals on the HX board, but I just prefer the ease of use/sounds of the stomps.
I've owned quite a lot of multi effects over the years ranging from the Korg A4 to the Fractal FX8, and the HX has been the best sounding/easiest to use by far.
Multi-fx:
Pros - make things easy around your feet, presets and if they have a decent speak simulator, serve as a back up to your amp or can be used straight to FOH and you have a good range of sounds.
Less cables, too and so hopefully, less risk of cables not working
Cons - If you don't like an effect, you can't really change it. You're stuck with what you've got
Digital (the majority of units) Vs Analogue
Pedals:
Pros - can change and swap out things easily which many of us like to do.
Analogue the majority of units) Vs Digital - individual pedal effects might sound better than the unit ones
Easier to identify and track down an issue in your chain
Cons - Interconnecting cables - these can be costly and these can go wrong, and I'm thinking of the issues I've had with solderless ones).
Unless you use a switcher (Gigrig Quartermaster, G2, Carl Martin, Line Selector etc) there can be a bit of tap-dancing involved to switch pedals or groups of pedals on and off
I have enjoyed using the ME-50 and 70 in the past
On bass, I really like the Zoom B3 and B1xON as apart from decent fx, they offer great direct to FOH solutions and sounds and can be used as a back-up
