I should mention that i gigged the TM DR for three months before lockdown.
By by the way, if they bring out a Super Reverb version and I am in a position to gig (fairly remote notion at the moment), I’ll be first in the queue
It sounds as good as I will ever need an amp to sound, either in the room or direct via the built in IRs. This and a decent overdrive is all I really need now for any situation. The only other amp I'm planning on keeping is my teeny Quilter TB200 in the wedge 1x10 Blockdock cab, for when I need to squeeze my entire rig into the boot of a Mini.
So yeah, it's good. I'd still trade it for a Matchless Lightning though
Trading feedback here
I'm really keen to see a tweed deluxe version or such down the line. I'd agree on it being the way forward, gives up a good tone, flexibility on the volume, really light to carry, no worry of carrying spare valves etc.
The worst write-ups I can find anywhere seem to say "it doesn't sound exactly like this all-valve DRRI at all settings" but that's hardly even criticism as you'll get similar differences between the 65 and 68, or 65 and handwired versions.
I note you can put different firmware on to update the reverb control taper and "remove the bright cap". There are new blonde versions with Celestion Neos too.
@Wazmeister - i'd be very keen to hear your thoughts if you go for one.
There is a sense of this being a weird place to be!
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
That said, I’ve never seen a dead one - or any at all apart from new ones in shops when they first came out. The thing that always worried me most about them was physical damage to the motorised knobs.
I was going to go out to my local blues jam then the world went crazy !
Is the DR loud enough for a band ? Can it stay cleanish at volume ?
The Twin looks ideal as a live amp.
So the key to whether the Tonemaster responds like its valve equivalent is probably whether the modelling accurately reflects that natural mid boost when you turn it up.
Is there really a 10lb difference or have they just messed up the spec listings?
