I have started doing a bit of home recording with Soundtrap/ Bandlab using the usb out on my Boss Gt-1000 as the interface into my pc. Whilst this works fine to get an actual recording the latency makes it unusable if you need to monitor. I have been advised to use the two xlr sub-outs on the gt1000 into and audio interface and then go from there into the PC which will apparently cure the latency. I know nothing about all this sort of this and wondered if anyone could assist. I have been recommended to look at the Boss/Edirol UA-25 ....is this a reasonable suggestion?
https://twitter.com/spark240
Reddit r/newmusicreview
https://www.soundonsound.com/reviews/boss-gt-1000
Bad latency is caused by a number of things...
1.check you have the latest "driver" installed for the GT1000
2.there will be a setting within the software to "set" the latency which it would be useful to check
i'm sure there will be someone with this exact or similar set up along shortly
