Found: Iomega Zip SCSI
lentolento Frets: 117
edited January 2023 in Studio & Rec £
Looking to see if anyone has either a 100 or 250mb scsi drive in working order.
Unloved, gathering dust or under the bed ....?
  • DiscoStuDiscoStu Frets: 5572
    I might have one. I can't remember if I threw it out in the last cull or not
  • jackiojackio Frets: 132
    I just need to check the same specs, but I do have a ZIP drive with some discs. I'll look it out tomorrow and get back to you.
  • KittyfriskKittyfrisk Frets: 19114
    I'll check too. I'll have a SCSI Zip drive , if I have 2 you can have one, otherwise it would have to be a loaner.
  • lentolento Frets: 117
    Thank you all so much  :)
  • FunkfingersFunkfingers Frets: 14594
    I also have a SCSI Zip drive and discs but I'm damned if I can remember the use to which I put it. (Maybe, an ancient sampler? Mostly, I use Iomega JAZ drives for that.) The other issues would be finding a working PSU and the correct SCSI format connectors for each end of the cable.
    OK found mine. It's a 100MB Parallel port ZIP.
    I don't think this is any good for you but shout if it is :)
    Grrrrr, just checked & remembered that I lent my SCSI Zip to a 'friend' who has long since pissed off. *facepalm*
    I do still have a Zip 100 internal from an old apple tower (IDE  Z100ATAPI) and a Zip 250 USB / PCMCIA.
    Sorry about that, let me know if it is of any use to you.
    Have need of one of these again if anyone has one ....
