Having not played my guitars for weeks, I got them out for a quick strum last night.
Oddly, they were all out of tune. Now, I know that's not particularly odd, but they were all seriously sharp. Never had that before, but whatever.
Anyway, I thought, maybe they're all like that. So I went through my acoustics - the two I'd made and my two Avalons. All the same. Never mind, quick work through with the tuner and they're all fine.
Except...
I bought an Avalon L2-20 off a member of this forum a couple of years ago. It's a fabulous guitar. I played that a lot, up until the lockdown earlier this year.
Never had a problem with it, at all. Changed strings a few times, nothing but beauty.
But last night, once I'd tuned up (or down, to be precise, given it was sharp), it buzzed like a pissed off wasp. The B, G, A and low E strings all suffer pretty bad fret buzz for the first three or four frets, the B string worst of all.
Eh? How can that happen? It's kept on a stand, in the middle of the room, a good 7 feet from the nearest radiator, a similar distance from the nearest window or door. I've adjusted precisely nothing since I bought it, and as I said, right up until I'd not played anything a couple of months ago, it was completely fine.
Is it the strings? Is it possible they've stretched out of their natural best, and detuning them from being sharp has loosened them to a point that they now buzz when they shouldn't if they were new? If so, why hasn't that happened with the other guitars, because they're strung up with the same brand (Newtone)?
Or something else I'm not aware of?
If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
The first time I tried a Brook acoustic.....the shop assistant took down from the wall hanger where I think it had been for a while. The neck was bowed backwards. Cue frantic search for the correct truss rod tool.....
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
if you don't have the tool, tune down 2 semi tones and see if the problem goes away.
If it does, you need to buy the tool. Send Avalon your serial number and they will tell you the allen key size needed
I have an old Larrivee one anyway, those are a better shape, but cost a lot
The Larrivee 5mm one is available here https://www.ebay.co.uk/itm/Larrivee-truss-rod-wrench-S-N-4001-39999-3-16ths-or-5mm-UK-stock/192895838220?hash=item2ce97ce80c:g:NBwAAOSwL7VWrdil - £23 - I used this on my old Lowden
You can see that it is shaped to go around the brace at the top of the soundhole.
I can't see how the standard Martin-style ones would work comfortably.
Ian
The only time you should normally detune a guitar for safety is for shipping, so the tension doesn’t cause or increase the damage if it’s dropped or cracked.
Dan Erlewine says to detune, which would be good enough for me even if I didn’t have personal experience as a repairer with shipping damage caused or worsened by full string tension - Gibson headstocks being the most common, but acoustic body damage too.
