Also useful as a tuner...
I wouldnt use a pedal personally as it will colour the tone to some extent.
Or maybe use a quartermaster so you can by pass all the pedal bumpf?
Or just eq the amp so it sounds right with the pedals in front?
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
Bear in mind that the output from the last pedal in your chain is what’s ultimately driving the amp. If you have a pedal with high output impedance last in the chain, it might affect the top end even if you have a buffer at the beginning.
At the risk of overdoing things, you could always try a second buffer right before the amp.
I don’t think GigRig make them any more but they turn up second hand occasionally. I took a punt on one for 80 quid on EBay and was very pleasantly surprised about it.
