I've never had a chance to do a side by side comparison - the only PRSes I've ever tried were CU 22 - so was curious what people's take was on this. Is there a significant difference between the two (beyond the obvious number of frets
While I have no real need for an extra two frets, I'm thinking it might be a good idea not to be too limited in a potential search, as 24s seem to be pretty plentiful...
I would imagine the neck pickup would sound closer to an SG given the placement - does the neck feels more "shifted to the left" too?
Thanks for any insight! I realise the easiest would be to compare directly in a shop or just try a used CU24, but obviously it's a bit trickier at the moment...
Click here to see me butchering some classic solos!
And I get a nosebleed past the 17th fret anyway.
I don’t recall ever using the last two frets on my original Custom and as mentioned above, the neck pickup sounded better (to me) on the 22.
Both CU22 and 24 can be spec'd with the wide/thin profile - But the Standard/regular is only available on the 24 and wide/fat is only available on the 22
Stoptail option on the 22 - Only the odd exception for a stop on the 24, to be the point of almost none
No hard fast rule, but I'd say as an overview, that classic old school rock/blues guys favour a 22 and modern/virtuoso rockers like 24's
Traditional Gibson based players will tell you that when you hang a 22 on a strap it feels right straight away, but on a 24 it is though the 'frets are not in the natural/right' position that you are used to
Kinda confirms my thoughts, given my style leanings a 22 would seem more appropriate (and I do prefer the look too, for what that's worth). Will still try to try a 24 at some point though, maybe I'll have an epiphany and realise I've been missing two frets my whole life (doubtful )
Also I gather having 22 frets allows the neck pickup to sit further up the string for a sweeter tone, and I think I'd miss that a lot more!
If you want a Custom, I would go for a 24 fret model on the basis that you’ll have more choice and an easier time selling it if it doesn’t work out for you.
If what you want is a PRS with 22 frets, a DGT or McCarty would be a much better bet IMO.
DGT also has a variant on the regular neck profile. I think it's the only way to get that profile on a 22 fret "Core" PRS.
I've been a long-term player of the 22-fret PRS models, but finally succumbed to a Cu24 last year as I couldn't resist a bargain vintage model. It definitely feels and sounds a little more snappy than I'm used to, but it's still very capable of covering thicker G-style sounds too. They do have their own sound, but the comparison to an SG isn't a bad place to start - especially with the Standard 22/24 models.
If you could only try one model then I'd recommend starting here:
That's super helpful, thank you. See, the problem is I like them all I'm equally happy playing Fenders and Gibsons, I really don't struggle with the shift in scale length etc. Which makes me think this could be a good opportunity to have something that's a bit more of its own thing (i.e. more modern, as all my guitars are very firmly in the vintage specs camp) - which to me sounds like a 24... Ha ha I could probably convince myself I need both by the time this is over!
I was totally wrong - the extra frets mean the neck pickup has to be moved closer to the bridge to fit the extra frets in which makes the neck pickup sound different. It sounds more like a middle pickup than a neck pickup on a 22 fret guitar.
Some people might not be bothered by the difference in tone and some may prefer the sound of the 24 fret neck pickup - it's just different; but it is definitely different.
It was the single reason I sold my Custom 24 and I did a lot of blind testing to make sure I wasn't just imagining it - recorded quite a lot of samples and I reliably could tell the difference.
If you like that classic Les Paul neck tone you can't get it on a 24 fret guitar, it just isn't as deep or round. If you don't particularly care about that sound I'd advise listening to samples of both neck positions and see if you have a preference.
As you say, though, there is such a better variety on the Custom 24 and a lot of special editions only on that model. I find that a real shame and also puzzling when PRS himself prefers 22 but maybe their C24 is their biggest selling guitar.
