Should this be in the studio section? I’ll stick it here I guess!...
Ok... today is spent making acoustic panels for the music room...
bought a sheet of 18mm ply and ripped it to 80mm planks
Grabbed some mineral fibre slabs... these have a density of 45kg/m3 so are more than up to task... plus, with that density I can make them thinner... only 50mm needed...
Frame cut so the opening is 1200mm x 600mm... same size as the slabs.
Braces added to the back to strengthen and to stop the rookwool falling out!...
Which gets me to this stage:
I have some hessian on it’s way to cover the panel and also some lightweight material to stop the rockwool falling out the back...
total cost so far? £105 which will get me 5 each of 1200mm x 600mm panels and two floor to ceiling bass traps!...
the cheapest I could find online was £80 per small panel!!!!
https://www.studiospares.com/studio-gear/acoustic-panels/acoustic-panel-1200-x-600-x-25mm-purple_465830.htm
You can't see it very well in the pics but the bass traps are actually built angled so they fit in the corners properly
@poopot nice job, very similar to how we built ours
these will do for cutting down some of that...
It’s only for basic music stuff tbh... most of my day is editing video!
time to crack on!!!!
Bare panel
I’ve always fancied having a go at making some timber “endgrain” ones like this: https://i.pinimg.com/736x/14/c5/64/14c564d3399339ea085b125cf5de059f.jpg
Not sure how much they will improve the sound, but always thought they looked really cool. Especially the raw timber ones, ie. not painted.
https://youtu.be/nvx5NYpDt1k
I suppose the wood's hard surface is chosen to deliberately reflect sound. Could you make the same profile out of something lighter - but with a similar surface - to achieve the same results?
My room's 5.5x4m, but I'm still in the decorating phase and haven't pinned down the treatment options yet. Was planning some of the OP's style of panels (and a couple on the ceiling).
It's the wooden skyline thing that looks like a test of plasterboard integrity.
you could swing from those fixings…
Nil Satis Nisi Optimum
One thing I have only just noticed in your photo is that your monitors do not look to be at ear level. Get them up! It will make a noticeable difference when the tweeters are pointing straight at your ears.
