Ah, the kind of issue that occasionally makes you want to sod it all and get a Kemper...
Recently, I started getting a noise like a tiny hoover coming from my amp, and I thought it might be a tube issue, but when I plugged straight into the amp, no noise. However, it turns out that when I connect my Chase Bliss Brothers I get that unwanted sound.
The pedal chain goes Polytune Mini 3>Brothers>Rat>Jam Delay Llama Xtreme>Timeline>Big Sky, and all powered by a next-to-new Cioks DC7.
I tried going cable to Brothers to amp and powering the pedal with a spare 9V PSU and the sound went but, when I remove or plug in the Mogami instrument cable to the amp (using the silent plug) I’d get a crackling noise where normally I wouldn’t. Connect the Brothers up to the Cioks again, and the hoover-like hum sound comes back.
Does this sound like a pedal issue or am I missing something? If there’s an issue with a pedal as wonderfully complex as a Chase Bliss, I wouldn’t know where to start...
https://youtu.be/8FTCQMj6sxM
... I’m still not sure, but the noise only seems to happen when both the Big Sky and Polytune Mini 3 are on the board. Remove the tuner or the Big Sky, no noise. Haven’t tried a different amp yet, but it sounds fine enough (bit of faint hissy white noise, though), but I’m pretty sure it’s the tuner, Big Sky, the Cioks DC7 or a combination of some/all of them that’s causing this omnifuckery. Jesus. This close to getting a multiFX or taking up the Hungarian nose flute instead.
