Hi guys,
just acquired an old silverface champ and looking to get a nice warm-sounding spring reverb pedal for it. I’d prefer to DIY a pedal, so looking at belton brick options like the EQD ghost echo clone from FuzzDog.
I then saw that BJFE do a DIY ‘spring in a pedal’ reverb, which obviously appeals to the purist in me. I’ve tried mini spring tanks before like the one in the Koma FX kit, and found it was a bit 1 dimensional and too metallic.
It’s got me wondering - for ‘authentic’ spring reverb sounds, is there a reason manufacturers have focused on the belton brick or DSP modelling rather than making little spring tank pedals? Are these smaller tanks just a gimmick, with bricks being a closer approximation of the large tanks found in these classic amps?
Which do you prefer?
If you have £££ then get an Anasounds Elements w medium or large tank.
It would be good, however I don't think they do kits anymore. I'm very happy with the Trem kit I bought a couple of years ago, sadly also no longer in their store.
The outboard unit is a bit hummy, which can be managed down with buffers and an iso tranny (in some circumstances the iso is pretty key), although for some amps it is far and away best in the loop. But for sheer glory of swampy, crashy reverb sounds, it's comfortably in front.
I think I had a look at that one. Thoughts?
https://moodysounds.com/en/produkt/universal-reverb-kit/
which looks mint, and can then get the biggest tank that will fit in the champ. Hence the next question - these reverb drivers, I see there are tube-driven boutique ones, FET drives, etc. How much of a difference does it really make? The BJF is 100gbp which is pretty cheap compared to the competition. Have no qualms about DIYing.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
If you want to go the DIY route, I am very happy with my build of Craig Anderton's 'Stage Center' spring reverb. I built mine into a 1U rack shell, but it is intended to be a pedal with outboard connections to the tank. I found a MOD medium-decay tank gives plenty of length and depth to the reverb, whereas the long-decay tank was just too much. I also found that the controls are mis-labelled in the schematic - see this post.
The Stage Center directly drives an 800 ohm transducer form a TL072 chip, which is the approach taken in a lot of modern production valve amps e.g. the Blues Junior. I don't think they lack anything, unless you're a valve purist when it comes to amps! Vintage valve amps tend to drive an 8 ohm transducer via a small transformer. I am currently working on a build of such a circuit, so I'll try to comment on the differences when I'm done, although other factors such as tank length may skew the outcome.
I already had the Fender Boss FRV-1 63 which is a superb digital spring in a box.
But the Uverbia is probably the best real spring reverb I've heard.
I've had to buy a bigger pedalboard because it's huge, but worth it just for it's verby goodness.
