I loved the Atkin.
However, when you consider the Guild is over £2000 less than the wonderful Atkin, then somethings have to be taken into account.
I wanted a cheaper guitar I can leave lying around, take outside, etc etc.
The Guild has a truly wonderful neck, and seems to bring more melody out in playing. It is rock sold in tuning (which is vital to me), and Im really quite fond of it.
The Guild def seems like a £1500 - 2000 guitar.
Just need a pick up system now...
Bandcamp
Spotify, Apple et al
Bandcamp
Yep. A K&K one. Still thin and weedy. Maybe I'm simply unlucky.
Bandcamp
Thanks for all the input guys...
So, as Ill be doing the installation myself (maybe), I have a couple of questions please;
1.) Which is easier to fit ?
2.) Or would I be better going for the LR Baggs Anthem and having it fitted by a luthier ?
@Danishbacon
@ICBM
Baggs anthem is definitely more involved and requires a small hole into the end of the saddle slot and a hole into the bridge and top underneath. It's also a more 'invasive' install, nothing that damages the guitar or really fundamentally changes is, but you'll now have things glued to the top from the inside, battery and a 'fallible' preamp. It's all mostly reversible though, except for the saddle holes and likely glue residue inside the guitar. If that all sounds scary, a luthier is the right way to go.
A soundhole pickup is the only type that's any easier - it will still need the endpin hole reaming, but apart from that just a screwdriver to tighten the clamping screws. Some install instructions suggest using sticky cable clips on the inside but I would avoid these - they never seem to stick well permanently, and you're better to just put a loose loop/knot in the cable or cable-tie it to stop it flapping against the inside.
Is there much difference in sound quality between say a K&K and LR Baggs M1/M80 ?
