Strymon Sunset - advice from owners please?
MrTeeMrTee Frets: 506
edited November 2020 in FX
Hi there, I've today received my used sunset, bought from eBay. Powering up using the same supply that my iridium uses successfully, makes the B light flash and 3 audible clicking noises. I have tried factory reset and alternative power supplies and still getting same issue.
Is this normal behaviour, or do you think it's a fault? Obviously I can return if not working correctly, but would rather confirm as it may be expected. Unable to find info in the manual either.
Cheers
  • Hmmm it seems to ring a bell with me when I had mine. But it was quite a while ago. Does all work ok after that sequence?
  • MrTeeMrTee Frets: 506
    Thanks. Yes, works fine once powered up/on. I've emailed seller, who directed me to a Reddit thread suggesting it's a common issue with DSP pedals related to the internal relay on startup. It's odd
  • hotpickupshotpickups Frets: 1822
    Message Strymon is your next step. They are really great in getting back to you. They always were when I had various questions when I had strymon pedals etc. It doesn't sound like a faulty unit though
  • BeexterBeexter Frets: 598
    Cheers
    Mine does exactly the same and works fine so I'd suggest it's normal.
