I think this is from 1980. Possibly 1979, Hard to tell. The so-called Gen 1 Ls have ebony fingerboard and bridge which this does have, Later Gen 2 had rosewood but it’s at the very end of that early run of guitars
The back and sides are definitely Laminated Indian Rosewood.
Can’t say weather the spruce top is solid of laminated
The neck is a very soft V, If you’re familiar with FGs then this is more modern feeling, less mass in the shoulders and satin finished
Nut is 44mm. Wider than an FG
All original with some very minor scratches, dings, imperfections
The neck angle is ‘OK’ not perfect but very usable. The plane of the neck hits around 1/4 down the bridge giving a saddle height of 2mm and 12th fret string height of 3mm
I’m near Bristol. if I’m allowed to offer safe collection then I do.Base theme by DesignModo & ported to Powered by Vanilla by Chris Ireland, modified by the "theFB" team.
If anyone has a cheap semi as a swap I’d be interested, Ibanez Artcore, Washburn or the like
