https://twitter.com/spark240
Reddit r/newmusicreview
I use it as a live mixer and a way of multi track recording gigs to sd card which i then take into reaper to play with them after.
I've used it as an interface before too, but, with covid etc my 2 input interface is sufficient for home use.
Great bit of kit, and I like than it has a more traditional channel strip setup, although I concede a digital mixer/recorder is maybe more flexible, this is just so straightforward to use.
Will be useful when we finally have a rehearsal space again!
For capturing practices or gigs, or location stuff it could be useful,,, but the screen limitations will impact editing. I have a Tascam DP32 and i never edit on it - sounds great though.
You will still want to move files. As a rehearsal/practice mixer.. it was tempting when it came out.
Although I haven't really experimented with standalone recording to SD card yet it will also replace the portable iPad/interface setup I was using occasionally. The DAW control mode I will experiment with, but maybe not use that much. It has so much potential in terms of how it fits in with your setup, it just seems like one of those great products that you're glad somebody makes - it's hugely versatile. There are a couple of quirks - the worst I can think of is phantom power is switched to all channels or nothing, so I have to check if this is only applied to the XLR ins, in which case it's safe to leave everything on a TRS jack plugged in. The headphone outputs (usefully, there are two) were initially set post the main fader, so when you turned the main fader down the headphones were turned down as well - useless when tracking acoustic guitar or something. There were workarounds possible with a monitor controller, running the sub outs into a separate headphone amp etc, but Tascam fixed it in a firmware update - strange that's how it was initially, but as it's a purely digital device and not an analog mixer with an interface and SD card bolted on, these kinds of things can be fixed in software.
If I had the spare cash, the Tascam looks a nice bit of kit, very versatile idea.
