Last year I had a problem with the volume dropping and tone getting distorted. Turned out that the multiway plug and socket on the PCB had got oxidised and had to be cleaned. Same symptoms are occurring so I'd like to check this myself so I can clean it instead of having to get it to my amp tech guy again - could someone kindly guide me how to access this?
There's also a possibility it's just a tube - if it is, would that be more likely to be a pre-amp tube rather than a power tube?
Thanks guys
... however, as this is a Laney you may have to contend with the chassis snagging on the poorly-glued vinyl - be patient if it doesn’t come out cleanly first go, or you’ll rip it.
If the fault is *exactly* the same as last time it probably is the same fault, but if it’s not quite the same it could be a valve - either a preamp or power valve could give a lower-volume distorted sound. The first thing I would try, before removing the chassis, is to take each one out and spray some contact cleaner into the socket, then put it back and wiggle it a bit, which will clean the pins.
as icbm said just be patient when removing the chassis is will catch on the vinyl somewhat, but go slowly and give it a little wiggle as you slide it out it will come eventually.
The previous set were JJ hand-tested which were much nicer than the Chinese Ruby valves it came with when new. It's only a single channel amp so it's about getting a good balance between nice cleans and a good classic rock crunchy distortion. In this regard I believe the circuit might even share some characteristics with a Marshall amp, but I'm not 100% sure.
I'd like to get a bit more crunchy distortion from the Cub but that might well lower headroom and not give me as nice a clean. @ICBM if you're looking in, any thoughts as to what pre-amp valves might suit or should I stick with JJ's? If memory serves, I seem to recall you quite like JJ's for power tubes but are not a great fan of them for pre-amp tubes.
If it was me I would probably spend a bit more and get an old-production RFT for V2 at least, if not all three - they're just the best in Marshall MV-type circuits (which this is, basically) in my opinion, but if you like the JJs that may not apply as much for you... try a Ruby back in V2 first and if it doesn't ruin the sound you're probably better to leave it like that.
So, having looked at a replacement set, I'm a little confused by the descriptions and price differences on what appear to be the same valves. For example:
Ampvalves.co.uk £71.40
https://www.ampvalves.co.uk/product/replacement-valve-kit-for-laney-cub12/
Guitarlodge.co.uk £61.40
https://www.guitarlodge.co.uk/product/laney-cub12r-valve-kit/
Interestingly, guitarlodge refer to a balanced ECC83S for the phase inverter in position V3.
HotRox £51.85
https://www.hotroxuk.com/laney-cub12r-valve-set.html
Karltone £56.25
https://www.karltone.co.uk/jj-el84-x-2-ecc83s-x-3-valve-amp-set-185-p
Karltone refer to platinum matching and premium tested, with a test sheet.
@ICBM I know you like Karltone and they seem competitive. But what's all this about a balanced phase inverter (I've seen this from some other tube suppliers too). Is this just sales talk or is this bona fide and needed? And are there any differences between these JJ tubes?
Please help unconfuse me!
I would not use a JJ or any Russian valve in V2. You’d be better to spend your money on a RFT and just keep ordinary JJs in V1 and V3.
A bit more I'd have been prepared to pay, but 4 x the cost for a single ECC83 just doesn't seem realistic especially as there's no guarantee as to how long any tube will last. I've read that they are more mellow sounding but darker with lower break up. As I liked the chimey cleans from the JJs I'm not sure how an rft in V2 might impact on that.
Is the Genelax Gold Lion ECC83 the same tube by a different brand name?
