R&R Solo 50, full two-channel 50W head in a single 1U rack space, it's the very one that Rob Chapman reviewed:
People say that it sounds very similar to a rectifier but without the excessive fizz
It's got a "proper" clean channel and a drive channel with two gain modes. The loop is switchable in/out and parallel/serial (with send/return/mix level knobs), and on top of that it's switchable 15W/50W and can be used as a preamp only with the power amp disengaged.
It’s been modified slightly - the original (apparently quite fragile) power and output transformers have been replaced with the ones from a Marshall 20/20 power amp (I believe), the maximum power output has been reduced closer to 40W. Looking for Sold
