The Mexico vs USA means nothing to me these days, I've had a few of both and would be happy with either. I had a player strat about a year ago and it was fantastic.
Not easy in the current market.
Which would be considered the better guitar ?
I'd go for the Vintera. I'd be a little concerned about the roasted maple neck. I think they are meant to be softer than normal maple. The Vintera also has the classic Strat bridge, not that two point thing.
There's a video that Peach did with Patrick Eggle and he explains that he uses roasted necks to help with stability as his necks are highly figured and figured wood often is less stable.
There is no doubt for me that roasting changes the tone as well (without being too cork sniffy). It darkens the sound of a guitar and takes some of the top end away. On a very bright Fender, that's a good thing in my view. With fat 50s, which are very bright, that's definitely a good thing.
I have another Telecaster (USA Fender) with standard Maple neck. My parts a caster definitely has more upper mid range presence - I've changed pickups / bridge saddles but the enhanced upper mids are still present. I put it down to neck but until I swap it out I can't say for sure.
It is definitely more stable in normal use. But overtighten a screw, or bash it on the headstock, and you will find its a hell of a lot more likely to split
Instagram
The dream setup has surely got to be Fat 50s with the second tone pot controlling the bridge pickup?
