https://www.thefretboard.co.uk/discussion/122981/milkman-the-amp-this-thing-just-got-my-attention/p2
Inguess I can always try and return if I don’t like it.
I've seen a few people rave about 'the amp' but never tried one myself, but do have the bigger milkman amps, and they are excellent.
Quick impressions:
The fundamental tone and feel is great. I always like to run some basic melodies on the higher strings and feel whether the notes have any “weight” or whether they sound thin. This sounds just great at low volume. I can see how this will be appealing to jazzers.
I connected my boost pedal and the results were very nice getting sweet overdrive in a black facey way.
what I did not like:
- Reverb is very musical, just great BUT I hate the decay soaked in and would only use it at one (Tremolo is also great but it’s more of a nice to have ).
- Headphones in is meh... sort of musical but I don’t think there is a cab sim there (?). For cleans it’s ok and not claustrophobic but that’s it.
Now milkman has the newer 100 watt version that has reverb decay and replaces tremolo with boost ....and takes the price to the rather high 799£.
Now I see why they brought in that one. I did not order that because I had a boost pedal, did not need the headroom and I am usually not picky or enamoured with reverb so I thought it would do the trick ok.
Kind of thinking of getting that one but at that price other options kick in (tone master , henriksen blu).
- My speaker is 60w rated and the 100 was a bit dangerously overpowered.
- I contacted milkman and they told me there is a decay knob and different reverb/tremolo modes inside the box ( I am yet to open it). That will surely resolve the surfy default decay.
- they also told me the cab sim on the headphone out is switchable
As I said, I really like the tone and with these couple of clarifications I think it ll be just fine. I do have a lovely boost pedal and that helps a lot with overdriven sounds but I think I need to get a straight up simple drive. Generally speaking. Home level drive sounds suck big time so not sweating about it (heads to the Fx £ section).
Sundays are more about babysitting but I will have a run later today or tomorrow.
I actually liked the headphone out with the sim on. Very nice clean sound and the reverb adds a lot of space. I think it ll do just fine and certainly better than other things Inhave tried.
My little full tone boost really help as an always on thing to add a bit of extra sensitivity abs flavour.
Overall, I am pretty happy. It’s not cheap but I like the simplicity and how it sounds at low volume. Effects are really great (although I am sure people who have had 15 reverb pedals might disagree).
This amp also reaffirmed my recent suspicion that I really like guitars from the Gibson camp tone wise. I think it will sound great with a hollow body.
I still consider it a very nice amp but you have to consider the following use case: you are trying to play guitar and kids and wife are following you around and you have to constantly grab your amp and find another spot.
I think I may buy it again in the future.
btw I think drive pedals work fine with it. Probably the bigger one though is a bit better choice if you don’t want to bother with pedals (I don’t really).
Thanks for the info BTW.
with headphones it actually sounded pretty good too (better than the Yamaha).
I think it is more about use cases than tone. How you are going to use it makes all the difference. If I gigged, the milkman is pretty great (plus pedals).
I might try one of these and a 1x12 instead.
