WTB mojoaxe compensated wraparound bridge
HootsmonHootsmon Frets: 15987
edited December 2020 in Parts £
Like myself....aged
tae be or not tae be
  • HootsmonHootsmon Frets: 15987
    Huba buba
  • bad_alicebad_alice Frets: 259
    Might find a wider audience shifting this ad to the Parts£ section? Good luck with the hunt!
    Easily distracted and...oooh, look! A guitar!"
    My Trading Feedback can be found here: https://www.thefretboard.co.uk/discussion/62765/bad-alice/p1
  • FunkfingersFunkfingers Frets: 14571
    Which type? What guitar does it need to fit?
    The bridge stud positions on some guitars demand a wrapover bridge with a preset compensated ridge along the top for intonation purposes. Others are completely smooth with just grub screw adjustment at each end.
    cs junior Funky
    xmas BUMP  :)
    anybuddy?
  • andy_kandy_k Frets: 819
    edited December 2021
    I know the Mojoaxe is the most elegant solution, but I also know they are pretty scarce, especially second hand, I mean if you actually get one, there is nothing better to replace it with.
    Have you looked at the other couple of options out there, Tonepros etc.
    I have a couple of these going spare maybe, one has the intonation milled out of the top face, and the other has a bar, or bars, inlaid to do the same thing.
    I can try and dig them out if you are interested, but they are not as elegant as Mojoaxe for sure.
    Edit,
    also, if it going on a Custom shop junior, it might not work as well as expected, I think these are built to work best with an un intonated bridge, and string type will have a big impact.
    Thanks Andy...have my heart set on the Mojo
  • three_little_birdsthree_little_birds Frets: 25
    These are supposed to be good.  Cheaper too.
    https://musiccitybridge.com/products/the-savvy-intonated-wraparound-tailpiece-aged-nickel?variant=40840528756898
    Says out of stock but I think they've had them recently.
