I'm currently prepping my build for grain fill, stain and lacquer, and I keep seeing conflicting information on how far to go with the sanding.
Graham sanded it to 150 grit, so I was going to start with 240 grit, but do I need to go any further? Some sources I've seen say go to 320, 400 or even finer, but others say that beyond around 220 is unnecessary and actually can reduce the amount of stain that soaks into the wood.
If 240 grit is sufficient then that's great as I don't need to buy any more paper/won't need to spend as long sanding, but equally, I want to take as much time as necessary to get this right.
Feedback
Then once dry re-sand with 240g and 320g
Instagram
Instagram
Instagram
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Thanks!
