I have done switches on Strats and Teles but not Gibson Style Toggle Switch..
This is the second time a pickup has disappeared..
I have bought a proper Switchcraft Toggle Switch to replace the Epiphone one..
Do I just wire it like for like.. ??
All the wires in the exact same places..??
I am working with limited space too..
I am really tempted to pay someone else to do this one..
If it involves taking the rest of the electrics out..
I have an urge to do a runner..
How difficult a job is this.??
Is there anything I have to look out for..?
Thanks for any help in advance..
Whether the wires go to the same places depends on the physical layout of the stock selector switch.
To do the soldering, the selector switch needs to be unfastened with the correct tool and manoeuvred to the widest part of the F hole. (The pickguard will need to be removed temporarily.) Use something to protect the guitar's finish.
The hole in the guitar top may need enlarging to accommodate the threaded barrel of the American switch.
You may be lucky, Epiphones aren’t as tidily done as Gibsons.
Once you've removed the old switch via the f-hole, the string can be transferred to the new switch which will help you get it back in place.
An Epiphone switch usually has all four thin solder tags on one side and the thicker earth tag at the opposite end. A Switchcraft switch will have the output tags (that are soldered together and go to the jack) on one side and the tags for the wires from the volume controls on the other side, along with the earth tag.
When the switch is installed, the upper tag is for the neck pickup.
