Greetings folks,
My mother in law has a 20yr old Simon n Patrick 12 string that has suffered a headstock break. It is a guitar that gets a wee bit of abuse - played at church regularly and left in car boots frequently. The break is possibly due to a knock, but it is a mostly clean break along the scarf glue line with just a small piece of wood split along grain near the volute.
The faceplate is, i think, fibreboard as it is acting as a hinge right now without obvious fracturing.
I think the wood is mahogany/mahogany type for the neck, cedar for the top and unknown b&s.
It is also has a great emotional attatchment, having been bought by my wife and her brother as a gift. I do not know the monetary value, but that doesnt matter.
Given the glue line break, and no knowledge of the glue used, would the best thing be to separate the headstock completely, re-surface the pieces and re-glue?
Would you recommend adding in splines to strengthen?
Whilst ive built a few guitars, and am constantly fixing my own mistakes, ive never attempted a repair of someone elses guitar. How straightforward is it likely to be? The finishing will not be an issue.
As always, i'd appreciate any help offered.
Adam
https://www.amazon.co.uk/Titebond-5063-Original-Wood-Glue/dp/B0002YWZPW/ref=sr_1_6?adgrpid=53586413416&dchild=1&gclid=CjwKCAiA_9r_BRBZEiwAHZ_v19GNVU3HftR_CQyWhHtJCW5ZTOkjAUqh7l65-6__jjxLPYDn_o93lhoC6YgQAvD_BwE&hvadid=259055529540&hvdev=c&hvlocphy=1007171&hvnetw=g&hvqmt=e&hvrand=6797505337751349189&hvtargid=kwd-299904202490&hydadcr=14875_1829131&keywords=titebond+wood+glue&qid=1610038953&sr=8-6&tag=googhydr-21
Yes. Although you could try using high-strength epoxy, that will generally stick pretty well even to most types of old glue (although not PVA). I've used it successfully on jobs like this, always heated as well which thins it and makes it flow better, and increases the bonding strength.
Yes, definitely - that makes the strength of the glue joint much less critical. Especially if you haven't resurfaced the pieces, I wouldn't risk it without.
I would certainly use Titebond for a fresh joint, but it is notorious for not adhering well to non-wood surfaces, which includes old glue. Epoxy should work, as ICBM states, and hot hide glue is perfect when gluing to itself, but PVA and derivatives not so much.
Cheers,
Adam
I think if it was me I would try epoxy without separating, with the assumption that I would be using splines anyway.
Is there anything you could suggest to clean up the surfaces without separating?
