SOLD BlackHeart Killer Ant 1/4 watt Amp Head with Bitmo Mods £120
three_little_birdsthree_little_birds Frets: 25
edited January 2021 in Amps £
1/4 watt valve amp you can crank at TV levels.  It has a Marshall like tone with the right speaker.
Features completely overbuilt component specs, from one-watt resistors in the signal path to a double-sided PCB with two-ounce traces.  Outputs for 4, 8 and 16ohm.
This has had the Bitmo mods so it has an added tweed tone control.  The tone knob also has a boost on a push/pull switch.  The original amp was great with single coils but a bit dark with humbuckers.  The mod makes the amp much more usable with both.  It also has a line out though i have never used it.
The power tube is a Sylvania USA long plate 12au7, and the pre amp is a JJ 12ax7.
Amp is in good condition.
Looking for £120.  I'm based in Southampton.
https://www.dropbox.com/s/y57yhfb2dkgici3/20210113_151134.jpg
https://www.dropbox.com/s/smbap1qjolv4xxv/20210113_151223.jpg?
https://www.dropbox.com/s/zvwk54nyk1eljnm/20210113_151310.jpg
Any questions please ask.
  • rlwrlw Frets: 4703
    edited January 2021
    Ignore.
  • Ignore?
    I posted a semi facetious comment when you first put up the ad as there was no price or picture - they followed shortly afterwards - and that comment is withdrawn.
    GLWTS.
  • Cool ok. Thanks
