Blown Blues Juniors single-handedly paid my rent for a long time
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
The *definition* of the voltage has changed, that's all. The tolerance specifications were widened to cover both the old European 220V and the British/Irish 240V.
It's very much a thing.
You should re-set the amp for 240V to maximise component (including valve) life and reduce the risk of arcing. The reason Fender don't is that in order to comply with EU/UK regulations - which I don't think are likely to be different even now - the amp must be supplied for 230V.
The only reason the amps are even fitted with the 240V tap is because Australia, New Zealand and probably some other former British Empire countries still officially use 240V.
To be extra safe, when turning off for the last time before you do it, simply turn the amp straight off *without* using the standby switch first - that will allow the filter caps to discharge through the valves as they cool down.
It does not need re-biasing afterwards.
It will cope - they have to be proof-tested at 253V, which is the highest allowed under either EU or UK regs, so it's not going to suddenly fail even running at the wrong voltage. But everything in the amp runs slightly too hot, which over time shortens the life of some of the components, including valves (worse in amps like the Hotrod Deville which operate at the highest voltages) and in some amps (especially the Blues Junior) it can increase the risk of a specific non-valve failure.
is there a plug in voltage regulator available that could solve the problem without having to mod the amp
Although they're big, heavy, quite expensive and completely unnecessary when all you have to do is move two wires - which is not a 'mod'. You also may need a different mains plug on the amp because all the ones I know of have the 220V output on a Euro-style socket, for obvious reasons.
It took me 20 minutes this morning. All you need is a pair of cutters and a Philips screwdriver. And like ICBM and your man in the video says, all you need to do is unplug one cable and replace it with another. Do it.
