Right then, my amp journey continues. I have completed a small, but important, mod on my mighty Marshall.
http://imgur.com/gallery/DIO5iVPPlugging into the Hoffnine 4x12 is an eye opener. Much more fun than it has any right to be
I added a SPST on-on switch and another 1/4" jack socket. Replaced the hot wire coming from the small daughter board and taking to central lug on switch, remaining 2 terminals to hot tab on built-in speaker and tip connection on jack socket, respectively. Ground connection on jack socket to ground tab on speaker. May not be the most electronically sound solution, but on this amp it seems to work.
Thanks for the inspiration,
@ICBM !
Adam
