I preferred the 6L6 set up and swapped back fairly soon after.
I think a ‘J20 with 6V6 valves is not the same as a J10’, the latter being clearly designed around the 6V6.
Still, you’ll no doubt enjoy the experiment. Jesse always recommends EHX
Seriously though, as you look at the back the first one on the left is the rectifier, next two are the 6L6.
I’m going to give it a go and will no doubt change it back as it won’t sound as good
First thing was using the 6v6s - that helped a bit but it was still pretty loud for venues like pizzaexpress jazz club so I'd use the VAC all the way as well.
But the vac in my opinion also changes the amp ability to overdrive quite a lot.
Now that I'm pretty much just recording some guitar parts, I've bought a captor X and been doing some tests.
In my case I need the channel volume and the vac at least half way up to get that nice natural crunch out of the amp. Im not technical but only assume thats coming from the 6v6s and the vac srtarve the valves so they don't get into overdrive at higher settings.
So at the moment I'm using the captor X at -20db, vac half away and the channel volume at about 6-7.
Now I can also use the tone control a bit better and get that clean-up with the volume. Haven't tried with the 6l6s just yet but something to check.
If I'd go back to gigging I'd probably take the xcaptor with me and try to balance one of its attenuator settings with the vac for live volume.
