https://www.dropbox.com/s/rrsw2x39m4x7cia/design.jpeg?raw=1
...and this was part way through the process...
https://www.dropbox.com/s/d54h2701tqsumm6/joint body.jpeg?raw=1
https://www.dropbox.com/s/n58mlivxm5i24s6/11 string guitar.jpeg?raw=1
https://www.dropbox.com/s/88iwus640i2ujpi/close up.jpeg?raw=1
The jack for the bass is in the middle of the body, with a new small cavity routed which allows space for a single volume pot. Electrics for the 6 string is as before - three way switch plus single volume and single tone.
The strip added between the two bodies was to allow the two different contours to blend more easily. The 6 string body is wenge, and I guess the bass is ash, so needed a dark stain to match. I then reshaped the 6 string headstock and painted stripes on the bass headstock to make them match.
I may add on/off switches to both parts as the neck not being played can be a bit noisy.
