SOLD Engl E606 Ironball 20w head with F/S
Top quality German made lunchbox amp head. Supremely flexible that goes from super crystalline clean to extreme saturation. 2 channels - the first going from clean to crunch, the second going from moderate gain to really thick extreme saturation (think Mesa rectifier with a more refined twist and much less flubby bottom end). Has a built in boost (footswitchable) which takes channel 1 to proper crunch (think 70/80s rock) and channel 2 it adds significant extra chunk (think boosted rectifier). In case it’s not clear this has loads of gain on tap!!
Has a a separate master volume covering both channels so easy to balance overall output. The eq is really effective and easy to use so dialling in a good tone is easy. Has built in reverb which is surprisingly good and this along with the a master volume boost are also footswitchable.
One really useful feature is a built in power attenuator going from 20w to 5w to 1w to speaker off with dummy load. This makes it superb choice for home use and where you need a quieter volume but still want the pushed tube sound. Has a balanced line out for direct recording and a headphones output too so direct to monitors is simple. Really good fx loop so all set for 4cm if required.
This goes from whisper quiet to easily enough headroom for small to medium gigs (they will return!!).
In near perfect condition and supplied with a bright onions aftermarket footswitch (top quality) which allows for two functions to change (either channel/boost or volume boost/reverb). You could add another and have all options at your feet. Only had home use and lightly at that!
Only selling due to purchase of a Diezel VH mini. Limited scope for trades
Asking £525 and that includes courier delivery within the U.K. sold 20/01 @ 18:30
