So I've been writing music while we are stuck in the house and I have a lot of ideas. In fact I have 15 songs written all pretty punky heavy rock type songs.
Anyway I have been using a multitude of guitar plugins from ampltube 4, guitar rig 5, logics built in amps, ML amp plugins and even considering Plugin alliance stuff.
So at the minute I have 2 guitar tracks paned left right both playing slightly different things so it got the idea of a 2 guitar band and have some melody lines over the top that pans slightly to the right.
I want to get the best beefiest guitar sound for the left right paned guitar tracks and wonder if doubling the tracks by copying and pasting in a new track and using a different plugin and amp from what I have at the minute would beef up the sounds and would this be a good idea.
For the main sounds I'm using amplitube 4 rockerverb with mesa cab and 2 mics panned right and a marshall jcm slash with vintage marshall and 2 mics panned left.
Any advice would be cool.
https://twitter.com/spark240
Reddit r/newmusicreview
I sometimes run through 1176 hardware but barely touching it, essentially using the 1176 line amps.
You don't really get that with a plugin though.
I mostly use a Distressor, API 527 or a UA LA2a on electric guitar, if anything.
In terms of duplication of tracks, you can detune the copied version but it is a specific sound (80's).
Better just play it twice and let the natural variation between takes full up the sound.
Remember to high pass the guitar to make room for the bass, I like 80hz for that unless you are playing metal.
Sometimes 120hz, depending on the register.
https://soundcloud.com/bill-saunders
I disagree with high-passing on guitars. A high-shelf is better. High-pass filters cause phase shifts further up the spectrum that I think can spoil guitars quite a bit.
Sometimes 2 tracks hard panned and then one with a slightly different tone straight up the middle can work too. But the middle one you bring down in volume so it doesn't clutter the centre.
1176 can work on high-gain guitars, but you could also try a clipper. That can help add a bit more aggression to the guitars as well. But go lightly with it!
Make 6 copies, copies 1 and 2 are tuned up 2 cents and down 2 cents respectively, and panned 2 clicks left and 2 clicks right. 3 and 4 go 4 cents and 4 clicks, but in the opposite directions. 5 and 6 go 6 cents and 6 clicks, again, swapping back to the original directions.
Then send all 7 tracks to a bus and eq to taste.
Just because you're paranoid, don't mean they're not after youGood call on a clipper.
Also check this out: https://www.fieldingdsp.com/reviver
I use it a lot on guitars and synths.
Bandcamp
Spotify, Apple et al
Bandcamp
All the creative techniques in terms of editing and effects tricks should never really be a replacement for 'play it tight twice'.
If you can't play a repetitive 2 bar riff tight enough to put on the left and right channels without it sounding wrong then that is the thing to work on. You won't edit your way out of that particular problem.
Genuine question - of course, it's your mix and if it's right to you it *is* right. But my experience of duplicate-and nudge in time is that if it's enough of a time difference to avoid comb filtering with the un-nudged track, it's enough to hear as out-of groove (groove and feel being a matter of milliseconds). I just don't see why you'd ever do it over either getting a proper double done, or just being happy with the single track - and I'm not alone in that.
Bandcamp
