Just thought this might be of interest to some, but who knows!
Wanted to mess around with drum recording and mixing, mainly to see what I can achieve using a stock mixing template.
I've learnt that my current template is a bit over zealous on some of the compression and eq, and that I need to refine it.
For reference; 7 mics in place are kick, tom x3, snare and two overheads.
3 audio passes, 1st from my phone which is a Galaxy Note plus, about 4 feet away at face height. 2nd is the unprocessed sound from the mics, and finally the results after applying the template I made.
Just because you're paranoid, don't mean they're not after youMy Trading Feedback | You Bring The Band
Just because you're paranoid, don't mean they're not after youBandcamp
Spotify, Apple et al
Just because you're paranoid, don't mean they're not after youA couple of narrow-Q cuts to get rid of a clashing snare resonance or thin out the toms where the bass guitar wants to be is one thing, suppressing everything between the fundamental and 3k is something else.
Not saying that's what you've done, but I am saying that removing that much midrange without there being any context to make sense of it makes the drums sound as @Stuckfast describes.
For full disclosure, I've made some pretty ghoulish drum mixes in my time that I am ashamed of.
Bandcamp
GIGO, as we used to say in the trade.
R.
Eqd Speaker Cranker clone
Ebay mark7777_1
Bandcamp
The only drum I'm not happy with now is the kick, as mentioned above. I need a new one, or at the very least a ported reso head with the mic inside.
The room is fine for most things considering it's a hybrid studio.
Mics are a mixed bag but I generally don't need them much for recording, they're more for gigs when it's just kick, snare and overheads. I've experimented quite a lot with placement. I have tried using my Aston Stealth on the kick batter head, which gives me a lot more attack.
Processing, as I said, this was a preset template, and I wanted to see how far from usable it is. The general consensus seems to be "a long bloody way!"
I'm working on getting my own preset sorted, which, as in any mixing I already do, will start with the principle of "don't apply it unless you can hear that you need to" and go from there.
Just because you're paranoid, don't mean they're not after youThe drum balance is going to change totally when a drummer takes over too.
You are barely touching the snare and the hi-hat is loud relative to the rest of the kit.
I'd be slamming the bass drum and snare (rimshot!) and tip-shanking (steady...) the hats.
You won't be able to use your template at all at that point.
You mike up drums with a mic. So it's "Drum Miking". No need to thank me, just doin' my jerb.
Bandcamp
Ebay mark7777_1
We had the luxury of trying a lot of different techniques at 2020 as there were quite a few days then the studio wasn't booked out and we could piss around with new techniques and different mics. I spent a lot of time learning the science but it varies massively between drummer styles.
One thing I always do though is set to a pair of overheads, kick and snare mice and listen to those making sure the snare is bang in the middle of the field and in phase with the overheads. That's a good starting point and there's a lot of mixes I've done that only really have that, not being a fan of close tom mic's (especially tom mics pointed down) .... almost never mic any cymbals except the hat and sometimes don't use that.
