Have been thinking about getting a Parlour style guitar, when I next change my acoustic, from my normal OM/000 size guitars, as quite like the smaller size and have seen some good video demos, but have never actually tried one, so would appreciate some advice, beforehand. Or should I stick with what I am use to!
So how does a reasonable quality Parlour guitar compare to an OM style guitar, besides size wise.
For instance being smaller, can they sound as loud, are they normally more brighter or can get a mellow sound, do you lose a lot of the bass end and are they easier or harder to play tension & action wise, due to being smaller, plus anything else. Also what gauge string would you normally use?
Many Thanks
In general, what they offered me (with varying degrees of success) was a tight punchy mid-range, bright and clear highs and some of that vintage boxiness for a pre-war blues tone. The Collings/Lowden were ultimately the very best of the bunch, but with eye-watering prices for such a small guitar. But all of them lacked the warmth, depth and bass that I was of course used to from an OM size. They were all easy to play from a string tension point of view; they typically have lighter strings on (10s or 11s) and most, if not all, were short scale lengths.
The biggest surprise for me though, was that I could never quite shake the feeling I was playing a 'toy' guitar (despite the price tags) and I didn't find them that comfortable to hold and play! Because of the very shallow body they sit low in your lap and I had to hold them at an odd angle to get the fretboard up for comfortable playing. I decided the parlor shape wasn't for me.
The search did ultimately lead me to a beautiful used Brook Taw (about 00 size), which had all the attractions of being small and portable and comfy to sit and noodle with on the sofa, but still having the dynamic range and depth that made it hugely rewarding to play. I'll PM you separately about this guitar, given our other discussions.
Good luck with the search, there are quite a few around once you start looking.
His is a Collings so it's going to be eye-wateringly expensive! but it does record very well and it doesn't hurt that he's also a very fine player!
I've only ever played an old parlour from the early 1920s, it was ladder braced and was built for gut strings, not steel, but it did have a fair bit of volume.
I reckon an X braced one would kick out some volume, it'll just be way more controlled and tighter than say an OM or a dred. I only owned it briefly as I bought it cheap on a whim off ebay and it looked pretty good... but it needed a neck set, refret and probably a new nut and saddle...so it would have meant sinking lots of money into it which I didn't want to do. Was very cool though.
On the other hand, it is often said that the OM is the best all round guitar ever designed.
There are so many great acoustic guitar manufacturers out there covering all price points. I was very impressed with a Martin CEO7 I tried (probably should have bought it), but it was pricey. I've also been pleasantly surprised with offerings at much lower price points too, but these tended to be larger bodied guitars. Some cheap parlours I tried before getting the Auden, were so boxy and stiff sounding that I nearly gave up looking at the model size completely. With small body acoustics in general, I'd definitely try before buying (when that's possible), or at least ensure you can return your purchase if it turns out not to be what you want. The OM body size is a wonderful all-rounder, so you may well be giving up something if you go for the convenience/comfort of something smaller.
Moloney music in Galway is an agent and Ciaran Moloney should be able to tell you all you want to know about their specs.
