Replacing the 9v DC in on an old EHX pedal.
frankusfrankus Frets: 4719
So I've got this lovely old Small Clone and it's got that stupid DC in
I'm happy to remove the old one and ream the hole till it's big enough for those barrel like 9v dc ins
but does this do the same thing?
http://www.maplin.co.uk/p/21-x-55mm-single-hole-fixing-dc-socket-jk09k
will the ring being positive and tip beign earth sod it up? I suspect it may.
  • ICBMICBM Frets: 72575
    edited July 2014
    Yes, because it will short the positive (sleeve) to the casing (ground, negative).
    It's really better just to get a converter cable so you don't have to modify the pedal. I just did with an Ibanez 8 series for someone like that.
  • frankusfrankus Frets: 4719
    as I feared :( got any ideas where to get the adaptor from?
    Don't know, I just made one with the socket end of an old daisy chain and a right-angle 3.5mm plug.
  • HeadphonesHeadphones Frets: 992
    I've done it on a few EHX pedals, makes life a lot easier than yet another odd cable, but not with that sort of thing; try this
    The same thing is available in other places it's just the location I recall.
  • shadyshady Frets: 252
    For god knows what reason I can't get a link up, but pedalstuff.com do a DC socket to 3.5mm jack plug lead - would that be the fella you need?
    The link seems to be wrong..
    This page shows the thing and how to wire it.
    And Here's a connector on ebay
    Not winning here.
    The How page again
    The E Bay Page.
    Whenever I try to edit the earlier posts I get an error message:
    There was an error performing your request. Please try again.
