Depends on your needs of course, but the Ammoon 5.8GHz and Lekato Ws50 5.8GHz (which are very similar) both come out with great reviews, very good tonal quality, under 6ms latency, and are inexpensive at around £40-50 for the Lekato & £50-60 for the Ammoon. Both are reported to last around 5hrs between charges but at that price you can buy two! Very compact too. You could also buy one 5.8GHz and one 2.4GHz for different conditions. The Lekato 2.4GHz WS80 gives up to 8 rs with under 5ms latency, and scores very highly in reviews and again around £40. Lithium batteries so should be no battery memory issues but even if battery life drops after a few years, these are cheap to replace.
The WL20 set, Lekato & Ammoon have the advantage of being compact with matching receiver/transmitter units, whereas the Boss WL50 & Line 6 G10/G10S need a mains powered base unit which is less convenient.
If you gig as well as being in the studio, the Line 6 Relay G50 is a very good reliable and highly effective conventional battery powered unit with terrific range and good channel options and control. The G30 is quite good too, cheaper, shorter range but personally I'd avoid it due to a weak battery compartment cover problem ( it breaks) that's never been addressed by Line 6.
A painful experience...
Cheap, simple, works!
100% agree.....haven't been set on fire with it either.
Uses traditional batteries, which I always have spares for, and lasts 7-8 hours consistently.
Super range and no issues. Also if anything catastrophic were to happen, you can plug a guitar in direct to the receiver.
Just because you're paranoid, don't mean they're not after youGUITAR WIRELESS SYSTEM LEKATO
LEKATO WS-50 5.8 Ghz Guitar Bass Wireless System Transmitter Receiver 4 Channels
was £39.39
https://www.amazon.co.uk/LEKATO-Transmitter-Transmission-Frequency-Rechargeable/dp/B07TWQL2JS
