I’ve recently made a fano style 3D model in AutoCAD and converted it to an stl file. I’m picking up some wood on Wednesday and hoping to get a colleague to cnc it in the next few weeks. Anyway, I’m happy to share the stl or cad file with you if you want to have a play with the model
m_c said: My woodworking is currently limited to manual machines, but from the CNC forums I frequent, the usual recommendations are whatever you can find on ebay/aliexpress for cheap which will usually do the job without any problem and are a good option for when you're learning and likely to break a few, or Wealden for good quality. Cheers @m_c - I've had the same guidance re the eBay 10 for £10 bits - oddly, they seem to do a job for once.
And I'll check out Wealden. Stupidly, I didn't think of them for CNC bits, but I use them regularly for my "other" router bits.
@guitargeek62 @paulnb57 - thanks guys. I know just how you feel. For many a year I've been envious of those with CNC capabilities. Luckily, it was a case of right place / right time - my neighbour had just decided to buy a bigger machine when I was talking to him, so he offered me this one. I didn't think long (at all) about buying it!
Fusion360 is still good and probably the most advanced, even with the newer free version limitations, but it does have quite a steep learning curve, especially if you've never done parametric modelling before.
There are however lots of tutorials on how to use it.
There are a whole host of other CAD/CAM options aimed more at woodworking, like Vectric and a good few others depending on what you're end goal is. If you've not found it already, a scan over the CNCZone.com forum board list will give you lots of options. Most have a free trial period, so you can try a few and see what is likely to work for your particular use.
I think my choice of package/s will be heavily influenced by the availability of online tutorials in English.
I've watched a few now, presented by Americans, whose approach seems to be to say everything very slowly, and then repeat it all, three times .
Only slightly frustrating .... !!
Once you've watched a few vids, you can generally work out who to watch, and who to avoid.
It was a bit of a surprise opportunity TBH. When the guy originally got it, I “expressed an interest” if he ever decided to sell, along with a few dozen others. Right place, right time, and I bit his hand off when he asked whether I was still interested.
I’m still on a near-vertical learning curve with all the software, but I’ve found some decent videos now, so making progress. And lots of sawdust!
If you've not discovered the world of feeds and speeds, then I use FSWizard - FSWizard Machinist Calculator
It's not the most obvious link, but if you click the "Run the Web App" button next to the iTunes/Play buttons, it'll open up the online version.
I've got the paid version, as I bought a HSMAdvisor license years ago, so I don't actually know the limitations of the free versions. I do know the paid versions let me store machine profiles.
I'm using Mach3 (preinstalled on the laptop that came as part of the CNC kit) to handle feeds/speeds, and have just left all those setting as they were thus far.
All part of the learning curve ...
You need to set the cutting feed rate (F word in the G code), to the maximum speed you want the machine to run during cutting. The machine might not hit that speed due to acceleration/deceleration constraints.
It's not an exact science, as it's affected by machine strength/deflection, cutter deflection, material deflection, and resonance, but the calculator gives you a good starting point, from where you can adjust cutting speed (Feed Rate Override is for this purpose), and spindle speed to try and find the sweet spot that works best.
If you haven't started already, I'd suggest learning the common G-codes, so you can understand what the code is making the machine do.
You'll rarely ever need to manually write G-code (I say rarely, but all my lathe code I do manually, as it's easier. The mill is all generated by CAM), but it's good to be able to quickly change things like speeds/feeds, without having to regenerate the entire file.
