Alternatively, some suppliers have a slotting and radiusing service.
I will switch to shorter hand held blocks once it's roughed in.
Obviously this method needs the board to be stuck to the neck already, but that suits my way of working.
Covering the board in white crayon helps show whether you are doing it evenly, and you can adjust technique if needed.
I am tempted by that GW jig though
Don't rule out a hand plane either, but best done before slotting
Instagram
It's not just the speed compared with using a block for ebony (45 minutes vs several days if you talk full elapsed time!), it's that at the end of the process, the radius and thickness is spot on...which it never is if I try doing it by hand.
Here’s my wife using it!...
https://youtu.be/cZj8nDORb24
takes about 5mins to radius... 10 if you go slow!...
although can save a bit by going for a cheap router. This one is a clone of a makita RT0700C for a third of the price, and gets pretty good reviews
https://www.amazon.co.uk/101748-Electric-Trimmer-Laminator-Joiners/dp/B00LVVJ99U/ref=sr_1_1?dchild=1&keywords=katsu+router&qid=1618305561&sr=8-1
I have one sitting next to me ready to try in a binding jig.
Instagram
I would certainly recommend the G&W system to radius fingerboards.
This is how I use mine, I've made a jig from 25mm Birch ply with a second piece of Birch ply 70mm wide on top. On the jig where the body end of the finger board is placed, I have a piece of plastic with a small piece of wood on top of that, this is to set the height up the router cutter. The first cut will be set a 6.5mm then the finishing cut 5.5mm. These measurements are for a 12” rad fingerboard, I will add .5mm to these heights for a 9.5 inch radius fingerboard. One other point that might be worth mentioning, at the nut end of the jig I have raised the centre part by .5mm, this will give I constant thickness to edge of the Fingerboard when the neck finished.
Before Brexit come into play I purchase the new version of this system which allows you to radius wider fingerboard. When I change over to this new system I'm also going to mount it on precision rails and runner, instead of running along the Birch ply.
Before I switch to the G&W system, I used a long bed linisher with a swinging arm above it. This was designed specifically for compound radius fingerboards, ether 9.5” to 12” or 12” to16”. It was a very fast way of radius a fingerboards, and very accurate.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
If I was going to produce another 20 guitars I'd probably knock up a router jig like the one above, but I'm probably only going to make 2 or 3 more. I don't have the space or the spare cash for more and I keep them all.
