Mine is powered by a single output from a Truetone Cs6 with no issues.
I think my L'il Moxie USB powerbank supply would power it easy, but I'd rather do it all from the same PSU.
And
https://www.amazon.co.uk/dp/B004FZ050G/ref=cm_sw_em_r_mt_dp_HYFCYGPGKHTFGJY2PFKX?_encoding=UTF8&psc=1
2 standard connectors (these will go into the power supply 500ma) soldered in parallel (i.e both positive on the same lug, both negative on the same lug) in the correct size Barrel ... Which I can't remember right now
Sometimes it'll be on my pedalboard as a pre-amp. So I've got the current doubler and a 2.5mm to 2.1 cable ordered.
Other times I might use it standalone with headphones, and for that I'll use a powerbank, and so I've ordered a 2.5mm to 2.1mm adapter plug.
I think that's all the bases covered. Thank you all for your contributions.
I'm looking forward to playing with my new toy when it arrives tomorrow. Initially I was looking at buying a new high gain amp - perhaps a 6505 MH, I was also looking at pedals like the Revv G4. But weighing it all up realised I could probably get everything I want with a HX Stomp into the return of my amp and also having a good headphone practice option too.
Bandcamp
Spotify, Apple et al
Not all power supplies can do this.
